Damaged Door
Hello All,
Someone kindly damaged my car over the weekend and took the surround from my passenger door window (picture attached). The problem is, I don't know what to ask/search for, or what the thing that was taken is called? Any idea how much a replacement is likely to cost?
Any advice would be most appreciated.
All the best,
Amanda
post-67281-0-22753700-1437427269_thumb.j
...forgot to say it's a 03 Ford Ghia, oops!
http://www.fordpartsuk.com/shop/ford___fiesta_mk6_5_door_lh_outer_front_door_moulding_f_1473674_c_118.htm
Genuine part and fits perfectly, just break off the old clips that are left on your door pillar first before fitting the new one, sometimes these fall off themselves due to the glue becoming brittle over the cold months.
what Russ ^^^ says is spot on.
I've actually got an unused (still in the wrapper) spare one from my Fiesta I sold in March but it's buried deep in the garage somewhere otherwise Amanda could've had it for nothing.
Hello Russ,
Many thanks for the advice and the link...you've made my day, I thought it would be much more expensive than that!
Best wishes,
Amanda
Your welcome Amanda, I dug out the one I had but it's for the rear passenger door so no use to you or you could have had it
