Mk6 Radio
Hahaha! Still providing help! And I'll have a quick look! Well I know what a tow strap is but never heard of it for a boot??
Hes looking for a link to his guide I think
  • Replies 116
  • Views 11.4k
  • GingerFlame
    GingerFlame
    Never heard of ripspeed. Personally I have a Pioneer AVH2600BT as a part of my ICE install You can find more on my build log
  • GingerFlame
    GingerFlame
    It's a double din, yeah. Lenny uses its bigger brother and he's impressed with the Pioneer range too. https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.pioneerelectronics
  • GingerFlame
    GingerFlame
    They're spot on They're touchscreen. Have aux & usb in. Av in. Av out. DVD & CD player. Bluetooth hands free & audio. Additional navigation module if you like. Carplay/airplay/mirrorlink
That sounds good to me!! What's a boot door tow strap??
Here it is mate,
Fitted last may,
Figured most people dont fit them exactly where there supposed to,
And i think it looks good as a boot strap lol
http://www.fordownersclub.com/forums/topic/70382-guide-fitting-boot-door-tow-strap-ford-focus-mk2-and-mk25/
Also here is Kieran's Mk6 build thread:
http://www.fordownersclub.com/forums/topic/63471-mk6-fiesta-flame-14-build-log-was-fiesta-mk6-5-door-custom-sub/
It does look pretty cool actually! Never actually seen this before but I like it!!
Thats a Lenny Exclusive rite there pal :lol:
Welcome to the edge of R&D
Thanks for linking my thread lenny.. thought I had already but turns out I hadn't
Thanks guys for all the help! I'm just useless with wiring and stuff like that but thanks so much!
Kieran has tge same model of fiesta so he can show you where he run his cables,
You need to run RCA down drivers side and power cable down passenger side to avoid white noise on the sub
Will lose you massive amounts of street credit
Yeah thanks! I'll see if my friend can show me as well! Dad has a rough idea but not sure if he knows! That amazon link for the radio, dunno if I should buy because will it be unused! I'm talking about the 2700
Pioneer would still have stock of the 2700 if it says its new condition then it would be.
You will also need an iso adator cable to convert the fiesta loom to aftermarket, simple plug&play process
my friend literally just sent me that haha
So lenny where would I find one and would the amazon link that kieran sent be my best bet??
Try Dynamic Sounds.co.uk
There generally cheapest uk supplier of headunits
Soundevo.co.uk is cheapest for speakers,
Caraudiodirect.co.uk is generally most expensive even Halfords would be like "Damnn thats pricey!!"
Rolling the bass :lol:
Hahaha!!! Thanks!!! Also while on the subject! Do any of you guys know how to install a bypass for the headunit ??
The radio is 6 pound more on that site but should I just go for them anyways??
A bypass as in handbrake? I may have installed one.
On the newer Pioneer units, mine included, a relay is necessary to bypass this. Unlike older units were you could simply earth the handbrake sensor from the headunit.
I had to import one from the USA which in the end cost me around £20 I think?
3 wires. Switched signal wire, Ground & handbrake sensor from head unit. Job done
I hardwired this into the loom as I bypassed the head unit whilst running my signal to the amps. I spliced into the cars loom for that. That left the wires I needed free from clutter so out came the solder
Yeah! So the videos and dvds will work while I'm driving etc! Just so the passenger has something to watch while I'm driving! Yeah heard something like that about the new ones! Thanks! I'm away to do my research just now! Should I purchase the headunit tonight??
Up to you when you order the head unit! . I'll get you a link to the relay tomorrow. Took about 20-30 days to arrive!
You Can play video from DVD as soon as either 1.) The handbrake is on or 2.) The relay Is wired in.
But to play video from USB, you must active the units DIVX device number. Free to do but easily overlooked
Well I'd like it to be fitted with the relay before 19th September as I've got to go on a long drive! The relay take long to fit?? And how do I do the divx?
The relay takes maximum 20 minutes to securely connect assuming you've basically knowledge of wiring.. its colour coded so blue to blue, black to black etc.
When you get the headunit, look in the settings. You'll find an activation code. Enter it in their site. Done
Okay! So once I fit the headunit! Is it much pain of taking it back out to fit the relay or is it easy enough? And okay that sounds easy
It comes with removal tools. Simply slide them in the side, wiggle & pull. Then unplug if necessary
Sent from my HTC One_M8 using Tapatalk
That sounds easy enough! Right gonna purchase it right now! If you could send that link whenever you get free time! No rush so don't worry ahah
I'll have a look tomorrow! Post on here before 12:30pm tomorrow to remind me
