Mk6 Radio
Haha I'll try remember to do that too! Thanks!!
  • Replies 116
  • Views 11.4k
  • GingerFlame
    GingerFlame
    Never heard of ripspeed. Personally I have a Pioneer AVH2600BT as a part of my ICE install You can find more on my build log
  • GingerFlame
    GingerFlame
    It's a double din, yeah. Lenny uses its bigger brother and he's impressed with the Pioneer range too. https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.pioneerelectronics
  • GingerFlame
    GingerFlame
    They're spot on They're touchscreen. Have aux & usb in. Av in. Av out. DVD & CD player. Bluetooth hands free & audio. Additional navigation module if you like. Carplay/airplay/mirrorlink
You got the link?
Ahhh it's not for the 2700
It works for the 2600.. don't see why I wouldn't for the 2700
Sent from my HTC One_M8 using Tapatalk
But if the one you sent works for the 2600 would it work for the 2700? It says that it's 2014 models and less! I might contact the seller and see
Send them a message. I can't find the exact listing I used as it's ended
Ah right! What one should I message?
Should I do them both
Its just a relay mate,
Wil work on all headunits which require a handbrake feed,
If your headunit has carplay then it needs to be connected to handbrake because carplay only works when handbrake is off,
Aswell as some menus change with handbrake off.
I have a switch in between the head unit & relay ;)
Couldnt the handbrake feed be run to an ignition live fuse
By using a piggyback fuse adaptor and a 12v rocker switch would be a quarter of the cost.
What sized amp fuse is the handbrake light?
Fit same size in the piggyback adaptor same results.
The handbrake feed wants an earth not a positive.
You could just use a rocker switch between the head unit and an earth point, but the head unit looks for a pattern, not a simple on or off.
Hence the relay switches in a regular pattern. You could just switch the switch a few times.. but I'd rather be able to switch the switch on or off and the relay do the hard work :)
Just had a look at this now! And wow this is confusing me ahaha! I'm so bad at the wiring terminology and that!
Ah i see what you mean,
Scrap what i said above;
The relay kit and a seperate 12v rocker switch would be the best option.
That relay kit will work on your headunit.
But which one? Because it doesn't state the 2700 in the compatibility?
