2002 Escort Van 1.8 Diesel (non Turbo) Engine Issue
Hi There
Have a 2002 Escort 1.8 diesel van with 101,000 miles (work horse) just lately its become ill
Last week its was driving perfectly until all of a sudden it started knocking & smoking
It has had timing belts along with water pump changed recently by myself ( ex ford mechanic ) & a full engine service & she was on the button as always
  • I have re-checked the timing both on the cam & the pump - Timing is perfect.
  • Removed the cam cover & checked the cam & followers - All ok & doing what they should do.
  • Cracked the fuel pipes coming from the pump to each injector whilst it was running and it went to cut out on every cylinder each time - Also swapped out the injectors one by one with a known good injector - Still running rough.
  • The engine sounds and looks like its off a cylinder at idle - It knocks & smokes (blue smoke) between idle & 3 thousand revs after 3 thousand revs it sounds & performs normal.
  • It drives OK and still has the same power as it ised to.
Going to remove the injectors again and perform a compression test on each cylinder to eliminate a bad valve or broken ring(s)
Head gasket OK & strats straight away
Could the avanced solenoid on the pump be faulty ?
Cranking note has changed slightly (timing ok though) & it's putin up through the inlet manifold on idle
Any ideas guys ?
