Hey Guys Mk6 Engine Swap
I want to drop the St 2l in my Ford Fiesta mk6 but what part of the wording do I need and do I need it with the key and barrel
Cheers
What size engine are you going from?
You may need driveshafts, gearbox, loom,
You WILL need ECU, clocks, key transponder from the donor car, keys, rear axle with brakes
May even need more
Team I can get the ecu and engine loom with clock and key chip would that all the wording I need
You also need the transponder which goes around the ignition slot. It's a circular thing with a connector on
Sent from my HTC One_M8 using Tapatalk
