System Check
Hi all,
System check keeps coming up ' check tyre pressures'... Checked on the inside of the door, put tyres to said amount, and woe and behold it still pops up 'check tyre pressures' Has done since about a week after I've had it. How do I reset this, can't hold OK down to reset like I can with averages
Matt
I would set the pressures, disconnect the battery for 30 minutes and then check the pressure again. if the pressures are the same as you left them, reconnect the battery. if the issue continues, then you probably have a bad sensor.
