No Indicators
Hi, I don't know if any one is able to help but while I was driving the other day my indicators just suddenly stopped working. When I turn the engine on and indicate it reads "right indicator malfunction change bulb" and the same for the left. I have changed all the bulbs which looked perfectly fine but it still isn't working. None of the indicators are working still neither are the hazards. However it does flash on my dashboard faster than usual, Can anyone please help? Any suggestions?
Fast flashing indicates a bulb failure - i'd check them ALL again
I could check them all again but what if this doesn't work?
A possible wiring problem could be the issue if all the bulbs are ok as fast flashing occurs when one or more bulbs are not working or are not receiving power or are not earthed properly
It could also be the indicator relay that is faulty or loose in it's fitting
Thanks for your help :)
No worries :)
  • 4 years later...
Hi there, did you find a solution to this problem, I have the same problem?
