Fiesta Mk6.5 Regular Beam Not Working
Hello,
This is my first post so please bear with me!
I drive a 2007 MK6.5 Fiesta Zetec, with little history of any problems at all. I got in the car late last night and to my shock, the regular headlights wouldn't work. All other lights worked - sidelights, foglights, indicators, full beam, etc. but my dipped beam and rear headlights would not come on.
First thing, I checked all the fuses but they all were ok (it would seem highly coincidental for them all to go at the same time), and had a look at the bulbs (again unlikely all front and back went at the same time). I also notice that when I try to turn my headlights on my dipped beam symbol does not appear on the dashboard, but my full beam, sidelight and foglight symbols all appear when they are on.
Through a quick search online it appears that maybe the headlight switch mechanism has broken - has anyone much experience in taking these out and replacing them? Is it a case of once this is broken I need to fully replace it? Or is it possible to fix? Any recommended places to purchase a replacement?
Thanks in advance for any help provided!
Craig
Try swapping the high and low beam relays over and see if the fault moves.
Relays are the 2 small relays top right in the fusebox. The far right one is the high beam.
  • 5 years later...
Hello,
Craig
Hi Craig,
Did you ever get to the bottom of this, the Mrs has just told me this happened to her car last night, so it's now my problem to get its fixed.
Hi Craig,
Yes he gave up after 6 years of waiting for an answer and got OAP bus pass. Craig has never been back to the forum since 20th November 2015.
