Dash Computer / Odometer Problem
Hi all
I've got a 56 plate Fiesta Zetec and there seems to be a problem with the Dash Computer, the one in between the Rev Count and Speedometer that displays the mileage and outside temp along with average fuel consumption etc..
Basically I was driving home this evening and noticed the display has almost faded completely! Its still lit up green (when the light are on) but the actual numbers and display you can barely see at all.
Anyone have any idea what the problem could be?
Thanks in advance!
  • 1 month later...
I have the same problem with my 2009 focus. I'll keep you posted if I find out/hear anything
Sounds like a bad connection. Take the cluster out, check the connections, spray with electrical contact cleaner and refut, this may resolve the issue. If not, however, you can send it for repair. there are companies who return it for £30 if no fault found, or do a full repair for £90.
