Nav Sd Card
Found an SD card online... http://www.ebay.co.uk/itm/FORD-NAVIGATION-SYNC-SD-CARD-MAP-EUROPE-F4-2015-/321962234899?hash=item4af671d413:g:XWIAAOSwf-VWXBhk
would I be ok getting this one, or should I get one from Fraud???
My dealership never bothered to send me one out, so that's why I'm looking at SD cards
Matt
Wrong one for your car
You got dab?
Yes I have, Got bluetooth as well so the centre console has more buttons than the star trek enterprise
The one you linked to is for touchscreen , that's f4. The one you want is v5 with dab. That's the latest one in led to believe. I just bought a v4.1 cheap off ebay couple of months ago, its updated enough for where I go.
Got a v3 for free if you want it.
I have a sync 2 sat nav with a F4 card, the nav is useless it does not recognise major roads from single track roads even on fastest route. Ford don't want to know even when I wrote to the CEO with the problem. Ford I believe know this software is crap. I have started using WAZE instead on my phone can anyone suggest anything. The sat nav on the ford even tells me to bear right instead of pulling into a lay by. I think it's the algorithm that have not been built properly.
how often do they release new maps i have F5 in mine
Jamie
Not often. Imagine every 18 months or so
Do you have the same problems with your sat nav
Ford are very cloke and dagger about the route guidance I cannot get anywhere. The card is about 6 months old and it says F4 on it I have been told by Ford it has the latest updates. I believe there is now a version F5 but no one is able to tell me what the difference is.
  • 3 weeks later...
hi,
greetings from Ireland
I'm new here
just got a 2013 Mondeo Titanium Business today
I need to source an SD card for the gps (touchscreen)
which one should I get? I'm a bit confused with the lingo here, V, F, MCA, Travelpilot
how do I see what I have/need? suggestions will be appreciated
  • 11 months later...
On 30/01/2016 at 9:32 PM, Trampa said:
hi,
I'm new here
I take it you have the MCA 7" touchscreen sat nav. Sd card is located behind the volume centre button ' the black panel and button pull off and you will see the slot.
