Burning Oil Smell
Hi, I have a ford Ka sport on an 03 plate, I had a bit of trouble with the thermostat stuck on it and it turned out a previous owner had fudged a repair and rounded off a screw so the garage was unable to replace the casing so he used a sealant to sick it together...something about being close to the head gasket and didn't want to cause any further damage. Anyway it solved the problem and have had no further issues with regards to the heating, but every now & again I can smell like a burning oil smell. I checked for leaks and is dry under neath and I park on a drive where I could spot any drips but there isn't any. The coolant levels are fine and no smoke appears it's just the smell. I can smell it from the front grill area but the bonnet isn't hot or anything...any ideas please
