New fuel filter -now won't start
I changed the fuel filter on my 09 focus titanium and now it won't start.
I topped up the filter with diesel, and after letting it soak, topped it up once more.
ive tried priming it with the ignition
the fuel lines are not swapped over my mistake
The filter and o ring is secure and tight
all nozzles are clicked in with their o rings in place.
does the system need bleeding manually? Is there a nipple?
There's no fuel cut off switch either and when I discount the the fuel lines and test it no fuel comes out.
im out of ideas!!!
please any help would be extremely valued
many thanks
Al
Fuel pump fuse blown ?
Sounds like it needs primed.
Your car might not have a primary pump so will need primed manually.
