Shark fin aerial
I'm thinking of getting one for the roof of my car, spraying it white so it matches and so on. Would it A work ( I've got Dab), and B would it look right?
This is the fella I've been looking at http://www.amazon.co.uk/dp/B00WA1PPLQ/ref=cm_sw_r_other_udp_awd_BQKPwbXEYYN4Z
Shark fin tends to look better towards the back imo, don't think it would look right at the front....
Very good valid point I hadn't actually considered tbh, ahhh well scratch that idea as drilling holes I ain't :tongue:
I always find the idea of how odd it would look interesting. After all, a sharks fine is in the middle :p
I am coming around / u turning on this, but I still ain't drilling...I'll get someone else to do it :tongue:
Try it first before you drill to make sure your happy with it no going back once the holes are made
I think it would look really strange on the front - they are usually on the back of the roof - I would just go for a stubby richbrook one if you want to change the look a bit.
I did see shark fin ones that look like they fit over the factory base though when I googled it so looked like no drilling. Would still look weird imo
I read somewhere that rear aerials don't work properly (if at all) for DAB reception.
Although I can't remember why it was, other than the signal will be patchy, if not poor to non-existent, from a rear placed aerial
Ignore^^^^^
Edited by GMX
Turns out to be incorrect
Ooh I might u turn back then, it was going to be on the back, I wasn't going to be doing the drilling though :ph34r:
I don't listen to the radio often but when I do I like it to actually be there lol
My aerial is rear mounted and DAB works just fine.
Oh well, whatever I read can't be right then:smile:
I want dab to work properly. Seems my standard aerial and connector doesn't offer great coverage...
Sent from my GT-I9195 using Tapatalk
Didn't Mindel get a Ford's DAB upgrade kit for the Mondeo (Part No. KITAERIAL2) replacing her existing aerial cabling, mount and aerial itself then?
http://www.fordpartsuk.com/shop/ford_mondeo_aerial_upgrade_for_dab_radios_f_KITAERIAL2_c_1402.htm
How odd! It's cheaper for Mondeos:cool:
unfortunately the pricetag was / is too high for my budget at the moment :( still trying to find it cheaper!
also thats for 2008 to 2010
