Location of rear fog light relay?
When i press the rear fog light button, nothing happens.
The bulb is ok, so I'm suspecting a faulty relay, occasionally I hear a short buzzing sound when pushing the button, but not near enough to identify it further.
I have browsed through forums, manuals, asked my way around - but haven't been able to find any information or diagrams showing the position of the relay.
Can anyone here point me in a direction?
S-max 2008 TDCi
Thanks in advance
Thomas (Denmark)
Simple answer is it hasnt got a relay as such, its controlled by the body control module, (fusebox assy)does the fog lamp warning light iluminate?
Yes, the dashboard fog light warning shows its on.
I was just assuming there was a relay of some sort since the front fog light (that works) clearly indicates on/off via a clicking sound..
  • 1 month later...
Try reset the bcm by pulling it's power (located under glove compartment) you will need your radio code after. May otherwise be a shorting prob
