SMax belt
Hi can anyone tell me how I get the belt on my smax I can see it goes over the pullys and round what I think is a tensioner but I cannot see how to adjust the tensioner
give us a clue what engine you have and we may be able to assist
Hi sorry its a 2.0 TDCI
Tensioner is spring loaded to should self tension, but to put belt on first , you need to turn tensioner with a spanner clock wise until a 4mm hole on tensioner lines up with another hole behind, then insert a 4mm dowel in hole, this locks the tensioner so you can easily fit belt, once belt is routed and fitted , use spanner to take tension off dowel and remove dowl and let tensioner do its job.
