Ford Fiesta Mk7 Rear Diffuser for my Zetec
Hi, I am looking to change the rear bumper of my Zetec. I quite like the ones seen on the ST's. Is it possible I could get mine changed to like the ones on the ST? I have a Ford Fiesta Zetec 64 plate 5 dr.
You need the corner spats if yours did not come with the style kit/pack..
Guide is here:
Loads of people done it already.. Here is mine.. with custom exhaust tips..
If you get the corner bits it's quite a simple job but you will need a custom exhaust or I believe Scorpion do an exhaust for a non ST with the rear diffuser so it fits correctly
Easy enough to do, & you only need an exhaust 'trim' for a few quid to finish the job.image.jpeg.08df29108b4f7a46ebb3e3e2083a6
True, forgot that
Check the "How to Guides"
You have been beaten to it as its already been posted up on this thread, lol
Can someone message Nathan, his the pics in his guide for the ST diffuser is now gone.
@BeebZetec it's pretty straight forward.
Need a drill to remove both the rivet on both corners, about two on each side. Then pull back the zs diffuser, start from one side. That would leave the side spats. Then just install the ST diffuser. They just clip into place then rivet the ends where you removed the rivets earlier.
The issue is the two "attachments" (don't know what to call them, see pic - the white bits) on the middle of the diffuser. On my zetec there is nowhere for them to bolt on. So I just cut them off. No problems so far.
Also had the diffuser Wrapped, its cheaper.
 That's interesting about the white bits as I have a screw like attachment there where the tabs go onto
Hi, i have been searching on Ebay for an ST diffuser. Do you have any recommendations for me?
This is how the back of my car looks at the moment. What parts do I exactly need?
20160329_101117.jpg.877cc200303d589d1ffa
From ebay:
http://www.ebay.co.uk/itm/Ford-Fiesta-ST-Mk8-Rear-Bumper-Lower-Diffuser-Trim-Spoiler-2012-/222058982869?hash=item33b3bf2dd5:g:U~4AAOSwr7ZW7cbu
http://www.ebay.co.uk/itm/GENUINE-FORD-FIESTA-ST-2013-REAR-BUMPER-DIFFUSER-SKIRT-/121919552364?hash=item1c62f8bb6c:g:yx8AAOSwZQxW4UFA
FordpartsUK: you need both, they clip together.
http://www.fordpartsuk.com/shop/ford_fiesta_rear_bumper__stone_deflector_primed_2013_f_1819019_c_1180.htm and
http://www.fordpartsuk.com/shop/ford_fiesta_rear_bumper_honeycombe_style_stone_deflector_f_1866724_c_1180.htm
Best to jack up the car (dont forget to use axle stands. SAFETY FIRST) so you can see what you are doing. So use the drill to remove the rivets, then pull the diffuser off(there are like clips but they come off easy). The diffuser (all the black plastic encircled) will come off and the ST diffuser will clip in there.. Then rivet it back in. Oh you need to have the diffuser painted or wrapped first..
The 'white bits' need pushing back 90 degrees. They then locate onto some threaded lugs that you bolt them onto.
  • 1 year later...
Hey,
sorry that I have to reply to an old topic.
I have the same problem as anyat00n with those two 'bits'. Do I miss something?
Maybe it's just the later cars or specific models they are original y fitted to.
  • 3 years later...
Hi, I have a 2009 ford fiesta zetec s. Is it possible to put a st diffuser on it so the exhaust is shown? The only thing I worry about is the parking sensors, does anyone know if this is possible thanks.
  • 1 month later...
On 3/28/2016 at 7:47 PM, anya00tan said:
Hi I am very late to this topic but where can I buy the rear spats? could someone send me a link? Thankyou. You need the corner spats if yours did not come with the style kit/pack..
Guide is here:
  • 1 year later...
can i fit a diffuser to a standard ford fiesta zetec ? if so which one do i get.
