sat nav
hello guys just like to ask cause i got a problem with my ford grand c-max 2011 sat nav..always vehicle out of line something like that.and I'm thinking of buying a new SD card on eBay you think it will work..Thanks guy if anyone can help me.
what do you mean by out of line?
its like the vehicle its not on maps
how many satelites does it pick up?
none
its was working before and all of a sudden not working now so i was force to by a garmin
in that case its probably the gps antena at fault, think it part of the radio aerial.
i need to check it tomorrow. appreciate your helps Ian Thanks..
easiest fix is buy a gps antenna off ebay with a fakra connector , remove radio unit and display, unplug the gps connector, connect up new gps antenna, and position new antenna anywhere in space behind radio/ display( its out of sight and still works fine
Thanks mate.. ill do that!!!!
i paid around £20 for my gps antenna, i have retrofitted sat nav screen and had to install an antenna,
let me know if you need advise how to remove radio.
