Long Pry Bar
Evening all,
So I've been finding that mines not long enough recently...  But pretty surprised how expensive the longer ones are!  Anyway, I do need to invest in one as I've got a few jobs coming up that will be far easier with a ~3ft/90cm pry bar for bottom ball joints etc.
Ideally want one with a handle rather than a claw hook at the other end.  Don't want to spend much but obviously want one that isn't going to snap on the first use.
So any preferred makes or a link to one would be great??  Online or instore, either is fine.
Cheers
Tom
I got a set of four pry bars ranging from the small 25cm, 50cm, 75cm and the longest is 1M all with handles, from the local motor factor a few years ago.  I vaguely recall paying £35
When I need more leverage, a scaffold pole will fit comfortably over the handle of the 1M pry bar:laugh:
If you just want the one, Laser have a 900mm with a handle
https://www.machinemart.co.uk/p/tool-connection-tc3206-pry-bar-jumbo-900mm-lon/
and Clarke have a 900mm wrecking bar type
https://www.machinemart.co.uk/p/clarke-cht822-900mm-wrecking-bar/
Ah, cheers Ghana.
More leverage than 1m?  What are trying to remove lol!?
I'd like the Laser one, but at the price of the Clarke...hmm... :wacko:
The Astra's rear axle when changing the the bushes, it was supposed to drop down once the bolts were removed: it didn't. The 1M pry on it's own made little difference but with scaffold pole extension, it was eased out with little resistance.
Here's a slightly cheaper Franklin Tools one ebay, seller does accept best offer too
http://www.ebay.co.uk/itm/Franklin-Tools-Jumbo-36-900mm-Pry-Bar-Prybar-Crow-Bar-/160663262204?hash=item256846d3fc:m:mhSXlt01EzeUomgtnIpsv-w
Your just needing some more muscle and a few more Chinese takeaways lol.
More muscle would be good, not sure I can buy that for £20 posted though. :laugh:
