programming key fobs
1 hour ago, iantt said:
sounds like it either needs enabling using ids or simular
"Select the <Toolbox> tab at the top of the screen.Select <Module Programming>, <Programmable Parameter>, <Power Door Locks>, <Interrnal Remote Receiver (GEM) - Enabled>."
something like that or could be a faulty gem unfortunatly.
what system you talking about software wise
that was fords ids software i took that info from, im wondering if forscan or elm config will check the reciever is switched on?  not used elm config but imagine thats the one to use.
ok.ive tried focom ,forscan ,elm
  • 3 years later...
Hi Guys.
After losing my original key, I went to use the spare however the fob didn't work (2006 Focus ST2) I have changed the batter and still no joy.
It unlocks the car fine and starts it, so I just need to re-programme the central locking function. Is there a video or way to do this? I have had a look through the above however it looks like that is to re-programme the whole key, which I do not require. And I certainly don't want to mess it up as I am now only down to the one key!
51 minutes ago, 9Freedman9 said:
Hi Guys.
Do you have an owners handbook?The sequence is in there 👍
Ah, really? Will have a look in that when I get home! Do you know what page it's on, to save me hunting through?
Cheers!
Do you want me to hold your hand when crossing the road😀
Cheers!
 seriously I don’t know for sure but probably is👍
It depends what else you will hold after really.
