Egr
Hi ppl wondering if anyone can help going to delete my egr valve on my Mondeo st 2.2 tdci mk3 06 plate I bought blank plate from e bay but the one on car has power plug can anyone help
Sorry, don't quite understand. The blanking plate is an extra item that fits between two existing parts, usually the EGR valve and the pipe from the exhuast. All existing parts, esp. ones with wires, will remain in place afterwards.
The PCM will notice if the valve is removed, damaged or jamming, but on many cars, it does not notice if the pipe is blanked so there is no flow through it. Some newer cars do sense the flow, and will need a PCM update to allow the blanking to be done without triggering errors & the MIL lamp on.
Ah a thought the original one on the car has wires on it and nothing with blank one
The guy on e bay said if mines has wires it will need a full remap again
Peter if a new how to send a pic my egr has a plug on left hand side all the one unit
Edited by Martinb1
Egr
Help what happens to these wires when egr plank plate goes on
I got this info from an Ebay seller's page, with an engine photo that matches your one closely. Looks like you have the Euro4, electrical version, so:
"EURO 4 type has the motorized valve, and the eml will come on without a hole in "
Also from them:
"I also have a plate with a 10mm hole in, (made from stainless steel) so as not to have the engine management light come on in EURO4 models, (item #110906768445) If do not wish that to happen.  But to get the best performance from your engine, or if your egr is playing up,  fit the hole-less plate and ignore the light( it will not go into limp mode by fitting a plate, but there are other factors/ faults combined with the plate that could ) "
I am not convinced about leaving the eml on, I think that it might be an MoT fail in itself now.
So you either need the version with the hole, which will not give a lot of benefit, or a PCM modification, which is a fairly complex & potentially damaging operation best left to a specialist. Or just leave it alone if it is working, or replace it (2nd hand ones are quite cheap) if it is not working.
The benefits of EGR removal are often overstated. I have tried my car with & without. When the EGR is fully working, there is hardly any noticeable difference. It is only if there is some malfunction that it becomes really noticeable.
Try fitting it anyway, and see if it makes a difference, then remove it prior to making a decision as to whether to replace the EGR or re-programme the PCM. The wires must remain plugged in to the EGR after fitting.
Best I can offer, I am afraid.
Thanks spoke to another guy he said leave full unit on and just blank it from inlet and that's it guys good but not sure what to do
Hi I have a focus 1.8 TDCI 2007 (57)
i blanked mine off with a solid s/steel plate couple quid off eBay.
dont unplug your egr it will give you fault codes leave it plugged in.
on the egr you will see a shape the same as the blanking plate your manifold goes to the back of it loosen the two bolts slip your plate in between them both tighten up again.
no faults should appear I didn't get any make sure you use s/steel as others will burn through and don't use one with hole in plate it's just pointless as your not blanking it off your still leaving space there.
If this is your engine bay then there's the egr where it blanks to
