Ka gear problem
Car has become very difficult to get into gear. Clutch fluid was low and topped up, and bled. Was left into Ford dealer and they found NO leeks and said nothing wrong. However, its still happening and the only way to put in gear is to pump clutch at start of journey. While opening clutch reservoir, it is on flimsy plastic bracket, which broke off. Ford say £220 to replace this!!! Has the clutch problem and/or that reservoir breaking off, happened to anyone else please ??
Sounds like there might still be air in the clutch hydraulics. It can be very difficult to get it all out of some systems, and may need repeated bleeding attempts.
I assume the fluid level is not dropping? If it is, then air could be getting in through the leak.
