auto recommendations
Hello all
I'm looking for all your experience to recommend the best Ford automatic to suit myself.
I'm a disabled driver and find auto box suits my needs now, my current car is a 2001 focus ghia (auto) 115,000 miles and I've adored everything about it eg handling,parking etc but alas its getting a bit long in the tooth and I fear may be near end of life.
My budget would be around £2,500 to £3,500 tops and I only do around 3,000 mpa, As you can see from my budget I'm looking for a maybe 10yr old or newer.
Hope you guys can point me in the right direction for value,reliability (auto)
thank you
rob
If you are elegible have you not tried the Motability scheme?
On 05/10/2016 at 7:02 AM, Stoney871 said:
If you are eligible have you not tried the Motability scheme?
You know I was going to suggest the above Stoney, I held off.
I am on mobility scheme.  I choose to spend that on a new car. Some prefer the money and buy a cheaper car That they would own out right.
Unfortunately You can only get mobility allowance if you get the maximum points in Personal independence payments PIP which is 12 points. if you only get awarded 10 points then you get the reduced mobility amount. This lower amount does not get you a car on mobility scheme. This may well be the case with the OP. Hence his budget.
