Needing my brake pads and discs replaced
Hi all,
new forum member, I have a 2011 Focus Mk3 estate - 1.6tdci
i need to replace the pads and discs - which I'm capable of doing myself, however I can seem to find a defined spec for discs and pads - can anyone help i.e. 300mm disc or not
thanks in advance
On 26/10/2016 at 11:24 AM, KeiranD said:
Hi all,
thanks in advance
You'll probably find the fronts are 278/280mm for the 1.6 diesel - if you're doing them yourself you'd be best going to a parts distributor - they will provide you with exactly what your car is meant to have.
Hi all,
thanks in advance
Eurocarparts, put your reg in and it will come up with disks or pads the correct size for your car!
