Service oil warning light
I have a service oil warning light coming on whenever I start the car. I have tried the clutch and brake pedal solution for removing it but to no avail.
Does this warning signify some sort of problem or is it just a timing thing for an oil change?
The model is a 1.6 TDCI  Focus Sport
did you have the door closed when you tried to do the reset for oil
yes all doors shut
for oil reset its brake and accelerater down then ign on, if that doesnt switch light off, then theres a fault somewhere that needs investigation
Will try that, I may have been doing it wrong by pressing clutch and brake
Have you actually checked the oil level? That light is the oil pressure light which means there is either a lack of oil or the pressure it too low.
Also when was the oil last changed? You have a MK2.5 with a 1.6TDCi engine. This needs to be done every 6000 miles to maintain a working engine.
Oil Warning now reset using gas and brake pedal
so was it due an oil change , or wasnt it reset last time it was changed?
  • 4 years later...
I have the same problem. I have just serviced the car ( ford focus 1.6 TDI 2013 model ) changed oil, oil filter and air filter then cleared service light by brake and accelerater depression but after an hour or two the oil service light comes on again?.
  • 1 month later...
I experienced the same problem as Keith Walker. So serviced car (focus 2011 2.0TD), cleared service light,  and 3 days later light back on, and stayed back on even after clearing multiple times.   Any solutions yet?
Have you put enough oil in and is it the red light on the dash you have comeing on
  • 3 years later...
I HAVE THE SAME PROBLEM SERVICE LIGHT WILL NOT GO OUT  WHAT EVER I DO ( HOW CAN I FIX THIS ???????????
Can you fix the shift lock first ?
