mondeo
i have 09 mondeo petrol now osf side light bulb and osr brake light bulb keep blowing when i change them,i checked fuses there fine any help on this fault
Have you checked the fuses are actually the correct rating? Also check any earths points too. Are there seperate relays for NS and OS lights? Could be an issue there if there is.
mot station said fuses were ok and correct ones they were talking about relays not mechanic minded so bit lost
Have you fitted the correct bulbs? Have a read of this -
http://www.honestjohn.co.uk/forum/post/?t=89695
If yours are working but just keep blowing then it does sound like more of a wiring or relay/fuse issue. Does your owners manual state what rating fuse should be present? I know you said the garage checked it but did they actually check the rating was correct or just that the fuse fitted had not blown?
