Fault codes
Hi I have the following fault codes P0033-77 and P0098-71  these come up every time after I clear the faults without driving. The car tends to break down with no power, it will not rev up showing messages such as engine system fault failure and power steering assist failure. After a couple of minutes it then shows reduced power. If I turn it off and then re-start it is ok until it gets cold and does it again. The other faults come up after a failure. Can anyone help I have checked most connections under the bonnet and replaced the alternator with no change, thanks.image.jpegimage.jpeg
