focus
Hi there all very new to this dont know if i am even in the right place, please could any one help i have a focus 2.0 tdci 2007 having a problem my car wont lock ac , heated front screen does not work  engine management light is on as is handbrake is permanently on & outside temp is blank then it will all come back for a short time then will lose it all again can anyone help please.o also indicators flash but no sound or visual from dash. jason
Edited by jrg30
mist out info
Check the fusebox under the dash.
Sometimes a connector on the bottom of the board can get kicked or knocked out slightly.
Check that all plugs are firmly seated.
Sent from my SM-G930F
hi there i will give it a go it went to garage last friday and came back like it its baffled them,i had a remap 6 months ago any chance this could be related?
as said by clive , check fusebox connectors
thank you have done that all seems good at the moment.
I have fuel temp sensor problem its reading 126 degree weather its connected or not had new one put on made no difference still reads 126 any ideas please, jason
