Fly by wire accelerator
Am I safe just to unplug and reconnect the connector for my fly by wire accelerator? As I had a diagnostics on it and it came up with a problem with it so I was just going to clean the connector and see if that gives it a temp fix? Thanks focus 2006
Yes should be fine no different to disconnecting the battery:smile:
Thanks! Also do you know where the cam shaft sensor is located as I have a problem with that as well? Stupid car
Its on the back of the camshaft cover on mine two wires come out of it :smile:
Brilliant thank you for your help much appreciated!
