Refuelling a diesel
Hi all ,
just got a new FOCUS ST 2.0 tdci and it's the first diesel I have owned . I refuelled the other day and it's the tanks first ever fill up . Payed the money and went to pull of the forecourt and noticed that the needle was only on three quarters of a tank . I heard diesel can foam a little which might trick tank into thinking it's full when it's not . If you guys could clear this up I'd be most greatful . Ta 👍
Yep, diesel is good for doing that!!  Hence why I never fill my diesels (or petrols for that matter) at "full blast" and only pull the pump lever about half way.  Granted it takes a while longer to fill but means when it does click you have a guaranteed full tank, or as close as you can get without overfilling.
What you can also do, although I don't suggest doing this if there is a queue of impatient drivers waiting behind you, is to fill it until it clicks then wait 2-3 minutes, and start filling again until it clicks a second time.  After a few minutes the foam should have cleared and you can then top it off.
I've noticed some fuel pumps click prematurely did same on my Fiesta petrol I think it's down to dodgy pumps. Never had an issue on my Diesel with foaming up.
Yes, sometimes that is the issue as well.  I find with those pumps twisting the nozzle sideways whilst filling alleviates the problem.
Good tip I'll give that a try next time
Some Sainsburys pumps do this, the flow seems set too fast and backs up into the filler pipe before the tank is full and trips the cut-off on the nozzle.
I've noticed that Sainsbury's are particularly bad for that, whilst Tesco pumps fill much slower.
Some new BP pumps do this on petrol too!
Sod the impatient drivers . For them I will hold at quarter speed lol
Haha!  That's the spirit!! :laugh:
I do too...fk em :laugh:
