Headlights
Hi I'm wondering there are four lights on front headlights one is indicator one is main beam and one high beam the other don't come on. Why? What is it. It's the closet one inside
probably the sidelights it's the smallest of all the bulbs 5 w 12V and they both  should come on
So there's two side lights. One in the circle lamps with the fog light and in main headlight?
One is a sidelight and I'm guessing the other is going to be DRL.
I can see you have posted this several times in the last couple of hours, try and post things once and just wait for an answer. Someone will be along to answer your questions, the right people to answer your questions aren't on here every minute of he day.
The ones in the main head lights are side lights yes two one each side. There is usually only one blub  each in the pair of fog lamps the fog lamp them selfs anything else  in there is probably an aftermarket DRLor something else a mod or something like that
It would be good to see a photo if you have one?
