rear brake caliper
hi, i know this will sound daft but can anyone tell me what a rear caliper holder is and if any photos would be great thanks
its the part that the caliper attatches too.
thank you, the reason why i asked was because for i had a rattle under my focus and at first i thought it was the heat shield then i removed 2 sections then still had the rattle so i removed the last section and still had the rattle which then i took the car into a garage and found that the rear driver side brake pads were loose so i had a mechanic come out and replace both sides with new pads and for some reason im hearing a slight knocking or rattle and the mechanic suggested that i get a caliper holder as the brake pad was rattling for a while and thats why im hearing this noise.
hi sorry its a caliper hanger not holder sorry
I'd call it a carrier, call it what you will it's the same thing.
