1990 p100 blue smoke on idle
I have a p100 1990 1.8 diesel . It is missing a bit and smoking badly.  The smoke is blueish  and worse on idle . Clears a bit when revved and smells of diesel. Anyone got an idea  what the problem could be and how to fix. Thanks in advance . Amanda
what you mean by missing? Blue smoke is a sign of burning oil
It is just running lumpy. And if you rev it it runs ok but then after a min of idling it starts lumping again I don't think it's oil as the smoke smells really bad of diesel
has is hard any work done recently ?
not as far as i know
would be worth checking any crank case breather pipes, make sure they ain't blocked, ideally need to figger out weather its burning oil or if its fule.
have you just bought it like this, or was it fine and got worse gradually, or was fine one day and then the next day suddenly went like this?
  • 3 weeks later...
have changed engine fuel pump / filter changed turbo and injectors and its still doing the same ????????/
Have you checked the above and the Turbo oil seals both of these  can cause blue smoke on a diesel and considering that its a 1990 I would definitely check the crankcase breather first On my older car before I had this one it often filled up with what looked like thick grease had to poke it out with a stick.
  • 1 year later...
Hi did you manage to resolve this issue as mine is doing similar tricks, starts fine runs fine but if left to idle begins smoking
  • 5 months later...
Valve stems seals perhaps.
