Fiesta Mk6 (2005) dash gauge colour change?
Hi all,
Just wondering if it's possible to change the colour of my dashboard speedo/gauge lights? (Shown in picture)
ive managed to work out how to get the cluster part out, however I need to know if this is a case of a bulb change or if it's a "skin"...not sure of the proper name for it.
if it is a bulb does anyone know the size of it? And if it's possible to replace with LED bulbs?
thanks in advance any help I would be really great full as I cannot find for the life of me any info on this.
If you're just after changing the colour, you can just get different coloured bulbs. This is provided the dash is a white light already. It should be dead easy to do if you know how to get the cluster out. Last time I did it all I had to do was take the cluster out, and the bulbs were pushed into a socket that was a quarter turn to remove it from the pcb, it sort of clicks into place.
You can replace with LEDs provided you install them correctly, remember they are a set polarity. I've never liked fitting LED's in cars, I've had everything from blown fuses to engine management lights.
Thanks both! Ill check if it is just a light as I think that'll be the best option, is there a way to tell which way around the LED is supposed to go as to not blow fuses?
Also with the Lockwood skin looks pretty good! However I'm not a fan of the white! :huh:
cheers guys appreciate it
It's not standard dome type led's that's in the dash, it's ones similar to these...... https://www.ebay.co.uk/itm/201382160264
They have a little groove on one side to determine between live and negative sides
Ahhh okay thanks for the info! I'll update with photos if I manage to do it!
It's not easy to get the polarity right first time, it's hard to tell on a lot of bulbs. It's very unlikely that you will blow a fuse by putting it in the wrong way, it just won't illuminate. That has been my experience.
You will also have to have decent soldering skills as the smd's are tiny (about 3-4mm x 2-3mm)
Take a look on metal monkey dials web.
Like i did on my mk1.5 focus 2.0 esp
Sent from my SM-G925F using Tapatalk
  • 3 months later...
Evening all I need some help I want to change my 2003 dials from green to blue I noticed it has green ink on the overlay and did look for the Lockwood white but I couldn' find the Lockwood with white face blue numerals any ideas where I can find them as the ones on eBay are white but with green numerals
  • 1 year later...
Can’t someone send me a link to the blue bulbs thanks
Search up rookie mods on insta. She can do this and also if you have a mk6 fiesta she does custom made twin cup holders also
  • 11 months later...
Hey guys, on the first posted image, there is the triple 0's in the bottom middle part of the dashboard. What is it for? I have pretty much the same dashboard and never figured out what is it for.
  • 7 months later...
I want to know if i can change the light bulbs on my 2007 mk6 or do i need to change my cluster
Hey i want to know if i can change the light bulbs on the cluster on my 2007 mk6 or do i need to buy new cluster?
