WET FLOOR WELL DRIVERS SIDE
hi all, can someone help please , I’m driving a Ford Mondeo titanium x sport 2010, I keep getting a wet floor well on the drivers side , does anybody know what it could be, some people have been saying all sorts of things like it’s the windscreen, pollen filter, wheel arch hole or door seals! Any body know an easy way to eliminate the wrong ones or an easy way to check please.
Are you sure it's rain water or could it be coolant?
Yeas it’s definatly water as it’s not got that distinctive smell of coolant
most likely is air con drain tube seal , theres a few threads about it on here sonewhere. i will have a look and post up link
Thank you
and
Thank you so much I’ll have a read
Quite easy to check then, just pop that cover off on the left hand side of the foot well and there should be that white drain plug, just pop that off with a screwdriver and see if it’s blocked! Hope fully it is and that’s the problem
yep, thats about it. let us know what you find.
Ok I will do, thanks for your help
Hi, popped off the drain plug and it’s clear as a whistle, got to be something else I think??
Did you check the other end also
How do I get to the other end?? It seemed to go downwards.
Just lift the carpet back a bit, the other end unclips from the body.
Just had a look, it’s clean but looks like a clip is broke, might have kicked it or something and it is damp in that area, any idea what this hose is called so I could buy a replacement or could I just fix it with a bit of silicone?
some on here have siliconed the seal and fixes it,
Ok I’ll give it a go tomorrow, thanks for all your help
