ETIS Update
Has anyone else had issues with ETIS since the format has been updated?
All I can get from a reg number is the VIN and the type approval number, no engine spec or equipment list. :unsure:
Been trying to check an if an early EB has had the coolant pipe fix as it's cheap(ish) and local.
9 minutes ago, alexp999 said:
Need to log in now.
Oh. :sad:  Do you have to pay to register or have I read that wrong?
You can register free as an independent operator. Or you used to be able to.
Yeah you still can to access specs, you just have to pay if you want wiring diagrams ETC.
Yep, you're both right.  I read it wrong, it says a fee will be charged after registration...and before access to technical stuff lol.
No outstanding actions so that should mean it's got the new coolant hose yeah?  2012 Focus 125ps.
If it says no outstanding field service actions then it should be done.
Easy enough to check if you go look at it.
Yeah, I just didn't want to waste the sellers time for the sake of 2 minutes checking ETIS. :smile:
