Folding electric wing mirror 2014 Focus Estate
I've discovered today that someone has either hit my passenger  side wing mirror or leaned on it.
Ford Focus Titanium Estate 2014
It's the electric folding type which still folds ok but is hanging out of the plastic plate where it's fixed to the door.
Im hoping it can just pop back in but can't see to do this successfully without risk of czusing more damage.
Does anyone have knownledge of how these are fixed or even fitted so can check underneath to see if anything is snapped.
Just realised I probably need to keep my question simple.
Dies anyone know how to remove or fit a power folding mirror. Without damaging further, I can't see any screw cclips to remove it/re attach to door.
  • 4 weeks later...
Any thoughts on this one?
Looks like it’ll clip right back in - no obvious signs of a break that I can see. - just use a plastic pry bar (something used for installing plastic trim) to place it back in. Should hopefully be a simple fix.
This happened to my daughters car also, I fixed it by taking the plastic cover off on the inside of the door, undoing the three screws
taking the mirror off repositioning it place again (make sure there is no damage inside)putting the screws back in place, make sure the electrical connection is ok check that it works and put the cover back on.
