Changing fog lights on a mk7?
I changed my headlights to a bright white xenon and now decided get the fogs too match but how do you change them? the owners manual is a bit pants as it just says go too fords?
any help would be appreciated!!! thanks...
Never mind i managed too do it now but if anyone wants help on it just ask!
  • 1 year later...
Yeh how do u get access to them, through the engine bay??
Best and easiest way is to remove your headlights, which gives you good access to the rear of the foglights.
  • 7 months later...
Hi i desparately want to know how to do this, just bought some LED H11 off fleabay and wanna know how to fit them when they come, there seems to be no clear details on how to get to rear of the bulbs to swap them out. is it the same for both the left and right hand side? any detailed instructions or pictures would be HUGELY appreciated.
kind regards.
Remove headlamp unit, giving easy access, then simply twist out fog lamp and replace.
Easiest way without even cracking the bonnet open.
For left foglight, put steering wheel on full right lock to expose wheel arch behing fog light.
For right foglight, put steering wheel on full left lock to expose wheel arch behing fog light.
There are 2 screws (could be 3) holding the thin plastic wheel arch in place which just pulls back when the screws are out.
By pulling the wheel arch back, the rear of the foglight housing is exposed.
Really easy to do, as ime always trying different foglights to match my xenons.
Finally settled for 68 LED cluster bulb. Match perfect with a 55w 5000k Xenon Dipped Beam, and dont have much light output as there only 10w, so use them as day time running lights (have them on at night)
