Mk4 mondeo
Hello  I have have a  Engine  fault light come on my dashboard on Friday so I got the aa put to see what was wrong they said it was this code
Patrol found the following fault code/s:System : Engine control 1 - 52Q / Diesel CR/EDC SID 206P1335 - Exhaust-gas recirculation valve. Error Message : Open circuit or disruption.P0489 - EGR position sensor B. Error Message : Control on lower stop.removed wiring connection
so any way he got the light to go out so he said if the light come on again I need to get it sorted well yesterday I parked I. Morrison to do some shopping when I come out  I started my car engine it started but about 5 second later it just cut out so try again this time I put my foot on the gas pedal to rev it up but Notting happen then engine cut out again  that happen 3-4 times then Eventually it work with the gas pedal since yesterday that has happen 3 times so I call aa out again he said he can’t fine any faults codes so he can solve the problem but he said the egr   valve can cause starting  problems so do u  recommend  me getting the egr fixed I was quoted £440 that with fitted
I would not spend £440 on the EGR based only on that evidence. EGR valves do not usually make an engine cut-out. And the lack of codes, and presumably no MIL (engine warning light), suggest there may be some other cause altogether. EGR faults usually do put the MIL on, with an EGR code stored.
EGR valves can often be blanked off with a plate. This usually prevents the fault from affecting the running of the engine, though it can make the MIL come on, and will not prevent the MIL from coming on if the valve is faulty. If blanking is possible (What engine do you have?), it may be a cheap way to test if it is the EGR at fault.
DTC code readers are cheap, easy to use, and an essential bit of kit for any modern car owner!
I got a 1.8 td when the light did come on the code did point to a egr valvue that what the aa guy said any way plus I point some egr cleaner In the air take this morning so hopefully that will sort it out
but the only codes on the car is a cruise control code but I know about that fault
2 hours ago, Chucky341 said:
1.8 td when the light did come on the code did point to a egr valve
The 1.8TDCI usually accepts an EGR blanking plate without any problems. However, this egr is probe to problems with the actuator, that is the electrical part, that cleaner will not reach or have any effect on. But you may be lucky!
If it is the EGR actuator, they can be bought for about £60, and are very easy to change, unlike the whole valve, which could cost well over £500 with labour.
Cutting out with no error codes sounds more like problems with a blocked fuel filter, or air or water in the fuel.
