Headlight adjustment
Hi i recently fitted aftermarket headlights to my 2010 focus problem is sinse then the internal adjuster has to be on 4 for them to remain legal is there anyway of resetting the internal adjuster without effecting the headlight height ??
You need to get your headlights aligned with the internal adjuste on zero, easy job at your local mot garage
ok thanks will do :smile:
Ok i went to my local kwik fit apparently the new headlights are fully adjusted to minimum so there was nothing they could do any other ideas ?
Not sure maybe you could pack the mounts so the tilt down more, what have you fitted?
devil eye headlights
