Puma 1.7 Clutch Slipping
HI I HAVE A PUMA 1.7 X REG
THE CLUTCH HAS STARTED SLIPPING LIKE MAD . NOT DONE BAD THOUGH AS ITS NOW GOT 130 THOU ON CLOCK .
IV'E HAD THE CAR 5 YEARS AND HAD NO PROBLEMS AT ALL APART FROM GENERAL WEAR AND TEAR AND THE RUST
AROUND THE WHEEL ARCHES WHICH SEEMS TO BE A GENERAL PROBLEM ON PUMAS .
HAS ANYONE REPLACED A CLUTCH ON 1.7 AND DOES ANYONE HAVE ANY ASSEMBLY DIAGRAMES .I HAVE REPLACE CLUTCH ON
ORION AND FIESTA BEFORE IS PUMA ANY DIFFERENT AND ARE THER ANY SPECIAL CONSIDERATIONS TO BE TAKEN INTO ACCOUNT
AS IM TOLD IT IS AN HYDRAULIC CLUTCH AND HAVE NO EXPERIENCE IN FITTING THIS TYPE .
CHEERS
BAGGY 1969
Hi, Can do you a genuine Ford Puma Clutch For a discounted price of £81.25 and you might want to consider replacing the clutch release bearing (hydraulic) when you are in there...common practice £75.62, the postage on these would be £10 via courier
Graham
(dont forget that with genuine parts the warranty covers parts AND LABOUR)
Graham
hi graham thanks for prices will let you know
baggy 1969
