Fiesta Engine Light
Hi i am new here , hope someone can shed some light on my problem please,
I bought a mk6 2003 1242cc duratec fiesta, this car runs great smooth as anything, however i have no way of knowing weather my problem came with the car when i bought it, or the problem as suddenly appeared as a new owner..
The engine was diry (not oily) just everyday dirty dusty, so i cleaned the engine with degreaser and rinsed it off with cold water, leaving the car to dry with the bonnet open.
The car was then parked up for a few days ,, yesterday i went out in the car,it drove and performed as it should!, all of a sudden the yellow engine light flashed 3 times then stayed on(i may of been in the wrong gear at a junction so the car struggled a bit) i then corrected the gear and carried on driving and the light stayed on, i did not lose that much power 30-40 miles an hour as normal, but it became sluggish every now and again, got home parked up and turned engine off. i left it 2-3 hours and then it started first time NO Light on everything ran fine again drives normal, today i went out problem occured again half way throught he journey (approaching a set of lights , i slowed down and moved of in 2nd gear, not fully coming to a stop, light flashes and stayed on got home turned engine of , after leaving it again engine seemed fine and started and drove as normal it did not give me an error code on the digital clock, when the light illuminated.
The car is an ex ford direct car, having done 90,000 miles but been well serviced fom new, i am on a low budjet having recently being put of work, without having to go an pay costly fees having it diagnosed from a garage, can anyone give me any possible causes for this minor glich, i.e the most common first... PS the man prior to me buying it had just had a new cam belt kit fitted at fords just generall not for any reason(mainly because of the mileage )
I must stress when this light is NOT on the car runs and performs superbly No misfires, stutters juddering or anything , just a nice smooth drive
Thanks for advice in advance
mark
mark
Found the problem, water was gathered on the black plastic cover that covers the spark plugs mopped it all up, and seems to have cured it..must have been my fault when i cleaned the engine
I have bought some new spark plugs as the others looked a bit rusty, they are ( bosch super plus) am i right in saying they should be pre-set i dont have to alter them, just put them straight in on the box it says 1.3mm does that seem right for my fiesta 2003 duratec 1242cc engine
thanks
thanks
1.3mm is correct.
