Ford Focus Zetec 61 plate rear electric window
Hi all,
Looking to fix passengers rear electric window as its not working, the switch does not operate from either the drivers controls or the rear switch, there is also no illumination on the rear switch. faulty switch or broken/loose wire maybe?. any info would be much appreciated. its a 61 plate Zetec 1.6 TI
Edited by ILR1975
Title Infomation
check the wiring in the convoluted rubber imbetween the door and the body. does the affected door lock/unlock ok?
Just noticed the door does not lock either and no power at window switch. The door stays unlocked all the time
You will need to check for broken wires then first, or corrosion at the connectors at the end on the convoluted rubber
When this very fault occurred on my car, the fuse for the door module had gone.
Fixed it months ago and the window & lock has worked perfectly ever since.
Fuse 118 for the left rear door on my car, check the fuse number for your model.
These fuses are in the passengers foot well.
ScaniaPBman.
ScaniaPBman.
good call on the fuses to check, think the car he has is mk3, so fuses for this are in the boot area im led to believe. fuse 6, 25 amp
cheers, will check them now.
Got in car to make a short journey and the window worked, stopped at petrol station and it no longer works!! door lock not checked while window was working though.
Evening all, checked fuses and all four 25 amp fuses are okay, these are in the boot on the left hand side. wiring in door has still to be checked. returning to dealer as only had the car for 7 weeks, 12 month warranty included.
  • 3 years later...
Did you ever get this resolved, i have the same issue and was wondering if a resolution was found, Thanks.
