fiesta tdci 2004 no cooling fan or A/C
Hi
I have a Fiesta TDCI 2004 for a while but the A/C has never worked ive had a new compressor & re-gassed but now the air con repair man says its not the air con at fault but its because the cooling fan is not coming on. I have checked the fuses in the car passenger side so im at a loss, does anyone have any idea why the fan does not come on?
fan relay fault probably. the relay is next to the battery. black square box with a tight fitting cover. pull the cover off. run engine , switch air con on and feel /listen for relay clicking. if you hve multimeter you can check feeds to the relay.
also there is a fuse in the engine bay that feeds the relays . 40 amp
If you don't have any luck with that, there's also a green, cyclindrical resistor on the fan cowling that can break, I've changed a few of those on mk6s.  Easy to bridge out with a jumper wire to test it.
Thanks for your replies, i had checked the resistor and in car fuse way back and they were ok, i have looked at the relay by the battery just to see if any smoke or damage but i will check to see if it clicks when A/C turned on.
Hi
i Have looked at the relay by battery there are 2 a grey & a black according to my Haynes Book one is for a  fan and other for the engine management, they should both receive 12v on  2 of the relay pins and they do. With the ignition on but not running engine they both have their 12v  i listened for clicking on relay when A/C turned on but could not hear anything.
Your thoughts would again be appreciated
Hi
i swapped both relays which made no difference, so now i stumped!
