Help identifying pipes to buy replacement
Hi could anyone tell me what the pipe that connects to this pipe on the exhast is called it had snaped.. thank you for your help
It's a DPF pressure pipe, should run up to the pressure sensor on the battery box.  You can buy some generic pipe to replace it rather than going to the dealer, just need to check what the internal diameter is.
Thank you very much
Silicon fuel pipe works well, 7 mm internal if I remember correctly, used it on my mondeos.
