Ford Focus 2002 service
Hello everybody. I have just reached my first 20.000 km in my Focus 2002. I always have loved Fords and when the opportunity came, I went and bought my self a Focus. After my first 20.000 km I am quite sure that my Foucs needs a service. Do you have any suggestions on what shoud I check for in my Ford? For example I check the oil level, liquid coolant every week or two. Maybe the water pump, or engine belt or something like that? I appreciate every suggestion.
Thank you
Just follow the service schedule Ford give you and you won't go wrong. But yes, you're quite a bit overdue on an oil and filter change at the very least. Depending on the milage you may be due for spark plugs, fuel filter, cam belt, aux belt, brake fluid and coolant.
You can generate a service schedule at https://www.etis.ford.com by signing up (free) and using you vehicle reg.
Thank you for the advice. I will most definilety take a look at the parts, components that you mentioned and other. Thank you againg, I appreciated it.
