Tailgate won't open
My 57 plate s max tailgate won't open not getting any noise whatsoever when pressing key or tailgate button any ideas please
Just had same with my S Max last week boot locked and not opening with keys or remote and no noise just indicators flashing - managed to get boot open from the inside after reading various posts but still no noise / working boot even though I have now have now replaced latch with a new one - Help! Need fixed asap and cant afford main dealer etc
the wiring will be broken in the convoluted rubber tube from the tailgate to the body. the tube on the left. needs pulling apart and rejoining broken wires as nessasry.
HI Ian thanks for replying - have checked and no wires broken - some had their protective covering split but recovered those - have had all trim off back and cannot find any broken wires at all so still stumped! Looked through all fuses that might be related in rear and also front passenger footwell and no joy best rgds David
You will need to check that both power and ground are getting to the motor connector - this will give you an idea of where any break might be (or faulty motor). A cheap £5 multimeter off eBay is fine for 12V car electrics.
  • 2 months later...
Dear All - thanks for your suggestions. SOLUTION after checking replacing the lock (which was faulty) the boot still would not open, but then noticed that the fuel filler cap was not locking when locking the car - checked and the fuse for that had blown, so replaced it and that made the boot work again! This is despite the manual stating that the fuse I replaced that fixed the boot only affects the fuel filler cap. So assume when the lock died that blew the fuse so once lock and fuse replaced all good .  Hope this helps other on here
  • 3 weeks later...
Hello everyone
I've got exactly the same problem on a 2010 fiesta 1.4 tdci zetec
I've been through and checked every fuse and all ok so I'm guessing that the solenoid for the lock motor has gone
Does anybody have any ideas how I can get boot open or get the lock assembly out with the boot stuck shut
Grateful for any help please
All sorted now got the boot open new lock assembly needed now
