LED DRL Upgrade
I’ve recently installed some new headlights on my fiesta, it previously had H15 Drl/mainbeam bulbs, the new lights have the led drl strip but are dim when they should be bright and bright when they should be dim, I’ve heard that this is solved with IDS. Does anybody know where this can be done. @Cookey09 did you get your lights done?
You can do this with Forscan. Free download. There’s a guide in here somewhere
HI mate, no I didnt, I opted to chop my 1.0ecoboost in for a new st3 not long after my post... I have heard forscan is the way to go or if you have a mate or are friendly enough with any ford dealers/mechanics they should be able to do it for you if you tell them it can be done through forscan...
I do know however that autobeam.co.uk do h15 LED bulbs now, which I wish were available for when I had mine, let me know how you get on with it mate.
  • 4 weeks later...
I took the car to ford, after four hours the technician said he had no clue how to fix the drls to work properly and advised me to remove my autobeam LED indicators because they were probably causing an issue, Ford were no help 😂. I downloaded forscan and within 5 minutes and the LED drls are fully functioning as they should and they look amazing
  • 1 year later...
That's really interesting. I didn't think it was possible to do this. What did you have to change to get it to work?
  • 3 months later...
looking for some pointers on this please.  I’ve just spent the last hour changing headlight and drl configurations in Forscan but still no luck.
Any help would be much appreciated.
