MAF and MAP readings
hi
I seem to be getting a high maf reading at idle. With Forscan, I get a pid of P0101 for the MAF.
The MAP values also seem weird, or maybe they are ok, no pid for the MAP.
The symptoms I am getting are a rough idle and fuel consumption is up
I have attached some values from Forscan and ScanXL  Taken at idle with  engine warm
MK2 Focus 2.0 TDCI 136PS   2005
Thanks for any suggestions
Dek
  • 3 weeks later...
Do you have an after market air filter on this? the oils may have fouled the MAF leading it to read differently. Give it a good clean with electrical cleaner - don't get too close or touch it, mind.
Otherwise, might want to consider buying a replacement MAF.
