Interior light
Hi
I am sure it's been asked before but can't seem to find an answer. I tried to replace the interior light bulb on my 1.4 2007 climate with a led. And it now won't work, can anyone direct me to the fuse location and what fuse it is please, i believe that it shares a fuse with the horn.
I don't have a work shop manual or owners guide so I can't check and loads of Google searches can't seem to help.
Thanks in advance
Steve
Did you try the Led bulb both ways in the socket, thy will only work one way round. Cannot help you with the fuse, I have a Focus.
Yes mate seen a little flash now none will work.
Early mk2 will be fuse 80 (10A).
Late mk2 is fuse 104 (10A).
The fusebox designs changed just before the facelift model came out.
Basically, if the majority of fuses are horizontal it's the earlier fusebox, if the majority are vertical (sideways) then it's the later box.
Sent from my SM-G965F (S9+)
Btw, it's common for the internal lamp to pop it's fuse when being fiddled with.
I blew a few in my time until I learned to pull the fuse out before working on the light. [emoji848][emoji4]
I have a mk6 well a 2007 I will have a check in daylight cheers buddy
Sorry, fuse numbers were for a Focus not Fiesta.
Best option is to check all 10A fuses behind the glovebox.
Thanks will do that cheers
Managed to check the fuse again in daylight and it was blow. Replaced it and it's working again now. There is a fuse layout guide stuck to the back of the glove box and is the same fuse that operates the horn. Cheers all for input.
