Abs fault
Hi everyone. Does anyone know if i should get A/C voltage from front wheel abs sensor on Mk6 fiesta. Tried with a oscilloscope. Get now voltage reading at all. New wheel bearing and sensor fitted. Thanks
Have you got the ignition on?  The 'active' sensors for these need power to work.
Also, are you sure the bearing was fitted the correct way round?
I can't remember if these are digital or analogue type sensors. Scan tool isn't at hand to look back previous data to confirm.
Easy to figure out, check another, known good speed sensor.
